Hello everyone,
I am trying to use the job scheduler on Aruba AOS-CX (6100 10.13.1000 ), and it works using :
10 cli copy startup-config tftp://<ip address>/folder/Switch123 cli, where Switch123 is the local hostname of the switch
I'd like to make a generic script that i can post to numerous switches, and which will fill in the local hostname at runtime, similar to using %h in a cron job.
I've tried various methods to escape the % sign, such as \%h , but everything I've tried has failed.
Has anyone found the right syntax to do this (if it's possible)? I've been looking for most of the day
Thanks!
