Auwave Upgrade Fails
  • 1.  Auwave Upgrade Fails
    Posted Mar 28, 2012 09:00 AM
    [root@monadnockamp ~]# start_amp_upgrade -v 7.4.8
    Directory not specified; using /root.
    Upgrade script found in local cache.
    Upgrade package found in local cache.
    /root/AMP-7.4.8-amp_upgrade: line 1: !DOCTYPE: No such file or directory
    /root/AMP-7.4.8-amp_upgrade: line 2: PUBLIC: command not found
    /root/AMP-7.4.8-amp_upgrade: line 3: syntax error near unexpected token `newline'
    /root/AMP-7.4.8-amp_upgrade: line 3: ` "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">'
    TIA
  • 2.  RE: Auwave Upgrade Fails
    Posted Mar 29, 2012 11:50 AM
    Try deleting /root/AMP-7.4.8-amp_upgrade and the tar.gz file and try again. It looks like a web page (probably an error message) was downloaded instead of the upgrade script.
  • 3.  RE: Auwave Upgrade Fails
    Posted Mar 29, 2012 01:54 PM
    I did open a case for this.
    Aruba is in the process of moving everything from Airwave over to Aruba.
    7.4.8 now lives within Aruba's domain, while prior versions are still within Airwaves domain.
    The script's URL  was pointing at Airwave for 7.4.8.
    When I orignally tried updating from the web it downloaded the script and failed. The workaround was to download the package to the root directory, delete the original upgrade script,  and run it again.
