Network Management
AW 8.2.10.1 - Cannot import to ESXI 6
  • 1.  AW 8.2.10.1 - Cannot import to ESXI 6
    Posted Jan 27, 2020 06:13 AM
    Dear Experts,
    When i try to import 8.2.10.1 ova file to ESXI, it gives me this error
    "The OVF package requires unsupported hardware.
    Details: Line 25: Unsupported hardware family vmx-13"
    Any idea what might be the issue. In server sizing guide, ESXI 5.5 or later is mentioned.
  • 2.  RE: AW 8.2.10.1 - Cannot import to ESXI 6
    Posted Jan 27, 2020 06:50 AM
    Check this vmware community link for fix and if you still see issue try use ISO image instead of OVA file and mostly OVA file is used for POCs.
    https://communities.vmware.com/thread/468121
  • 3.  RE: AW 8.2.10.1 - Cannot import to ESXI 6
    Posted Jan 27, 2020 07:04 AM
    Dear Pavan,
    Solved it :-) For anyone who finds this post while searching for the solution
    1) extract ova file using 7zip or winrar ( i used winrar). There will be 3 files. .mf, .vmdk and .ovf
    2) Open .ovf file in notepad, and search for line that is giving the error. My error was regarding "vmx-13" so i searched for "vmx-13"
    3) change "vmx-13" to "vmx-10"
    4) save the file
    5) delete the .mf file
    6) Import the ovf file now, it will work!
    I am doing this for PoC only. Cannot recommend above steps for production.
  • 4.  RE: AW 8.2.10.1 - Cannot import to ESXI 6
    Posted Jan 27, 2020 07:09 AM
    Good to know your issue get fixed :)
    Note: In future if you are planning to install server for production use ISO image.
