Cloud Managed Networks
Azure authentication package distribution, is it possible ?
This thread has been viewed 19 times
  • 1.  Azure authentication package distribution, is it possible ?
    Posted Feb 08, 2023 07:37 AM
    I have a aruba-central Instant-wifi setup with Azure-auth, a single ssid and this works, I paste the auth URL from the security web page in central into the web browser and login and so on, this provides the config for the SSID and all the settings and I am able to use the wifi.
    But I need to do this for a few hundred user, is it possible to package this into a single add that can be installed using group-policy in windows ?
    ie a executable that only needs the user/pass and then installs the ssid with correct settings. Manual process is not really the solution.
  • 2.  RE: Azure authentication package distribution, is it possible ?
    Posted Feb 08, 2023 10:04 AM
    Do you refer to Cloud Authentication & Policy in Central, linked to your Azure AD? That today works for BYOD/self-provisioning scenarios, but if you just distribute the registration URL, users will have the option to download the application.
    For managed devices, using Intune/MDM or Group Policies would be the recommended method to get devices provisioned fully automatic.
