Cloud Managed Networks
Azure deployment
  • 1.  Azure deployment
    Posted Nov 29, 2023 04:52 AM
    Hello all, I have to deploy a WiFi network for a customer with very specific restrictions. They want a secure solution (FIPS/NIST) without controller hardware, a centrally managed solution (no Instant deployment) that does not use Central.
    The APs will be deployed at multiple small locations with the ability to connect over the public internet (no private WAN exists) using IPsec.
    Any virtual controllers deployed can only be done so in a secure Azure environment.
    Can this be achieved?
  • 2.  RE: Azure deployment
    Posted Nov 29, 2023 11:13 AM
    Problem solved, after discussions we can host physical controllers in another environment.
