Azure OAuth Via Guest Captive Portal
  • 1.  Azure OAuth Via Guest Captive Portal
    Posted Dec 04, 2020 10:09 AM
    Hi
    I have a working Azure Oauth authentication via a dedicated SSID using clearpass as the NAC and a web login page with Cloud identity enabled. I now have a request to merge this with my dedicated Guest registration captive portal but once i have enabled the cloud identity i get a Incorrect Reply URI response from Azure. I have amended the reply uri in azure to point to the guest registration page but am still getting the same error.
    Any idea please?
    Jeremy Smith
