Backhaul indoor AP 210
  • 1.  Backhaul indoor AP 210
    Posted Apr 03, 2016 08:04 AM
    Hello Dears,
    I want to confirm, we can backhaul indoor AP 210 in a mesh with 5Ghz like outdoor AP's, right?
    If so, then what is the recommended number of backhauled indoor AP's per cluster, for an average goodput of ~ 12 Mbps per AP?
    Thanks.
  • 2.  RE: Backhaul indoor AP 210
    Posted Apr 03, 2016 10:01 AM
    Is this indoors or outdoors?
  • 3.  RE: Backhaul indoor AP 210
    Posted Apr 03, 2016 01:48 PM
    The first part is yse, the second part answer would need lots more information, like what is the channel bandwidth (20/40/80Mhz), is the channel clear, what type of client traffic, is the 5Ghz going to be dedicated to mesh and there will be no clients on the 5Ghz radios, etc?
  • 4.  RE: Backhaul indoor AP 210
    Posted Apr 03, 2016 03:04 PM
    Channel Bandwidth will be 20Mhz, and as far as I know, each Radio could be used either for Access or Backhauling, right?
    So, if we used 5Ghz for backhauling, we;ve remained with 2.4Ghz for Access.
    With 20Mhz, 800ni Guard, and AP 210 (3x3 MIMO), we can get upto 195 Mbps throughput, that should give around 80 Mbps goodput (Allowing some derating).
    So, it should be fine here, if 5Ghz Signal is clear for backhauling, right?
    Thanks.
  • 5.  RE: Backhaul indoor AP 210
    Posted Apr 03, 2016 05:08 PM
    Range and all that notwithstanding, I would budget for 60Mbps to give yourself some headroom unless you're sure these APs will be withint 10-15ft of each other, etc.
