Wired Intelligent Edge
Backing up 2930m switch configs
  • 1.  Backing up 2930m switch configs
    Posted Sep 25, 2019 10:38 PM
    New to the Aruba switches and still in the process of figuring out things. I'm trying to figure out how to backup the configs of the switches either by command line or gui so I can have a copy if a switch ever needed to be replaced, etc... We have 5 stacks in different locations. Thank you for your help, Matt
  • 2.  RE: Backing up 2930m switch configs
    Posted Sep 25, 2019 11:23 PM
    what switch firmware are you running at?
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/EntryId/10226/Default.aspx
    Backup the Flash File System in the CLI
    (host) #backup flash
    (host) #copy flash: flashbackup.tar.gz tftp: <tftphost> <destfilename>
    (host) #copy flash: flashbackup.tar.gz ftp: <ftphost> <username> <destfilename>
    (host) #copy flash: flashbackup.tar.gz scp: <scphost> <username> <destfilename>
    (host) #copy flash: flashbackup.tar.gz usb: <destfilename>
    Restore the Flash File System in the WebUI
    1. Navigate to the Maintenance > Copy Files page.
    2. For Source Selection, specify the server to which the flashbackup.tar.gz file was previously copied.
    3. For Destination Selection, select Flash File System.
    4. Click Apply.
  • 3.  RE: Backing up 2930m switch configs
    MVP GURU
    Posted Sep 26, 2019 01:18 AM
    it is for MAS switch
    for Aruba OS Switch, you can use
    copy run tftp://X.X.X.X/myconfig.cfg
  • 4.  RE: Backing up 2930m switch configs
    Posted Sep 26, 2019 07:52 AM
    Version 16.09.0001
  • 5.  RE: Backing up 2930m switch configs
    Posted Sep 26, 2019 08:25 AM
    On ArubaOS-Switch (formerly Provision switches)
    From the CLI; capture a show run to a text file and save it.
    From the Web GUI. Select Configurations> Management. In the right side, in the Download box, Click Download and save the file locally. It will default to config.pcc. PCC files can be opened with notepad or similar.
  • 6.  RE: Backing up 2930m switch configs
    Posted Sep 26, 2019 08:32 AM
    BTW, if you are using the Traditional web GUI instead of the Improved GUI, expand System and click on Updates/Downloads. Highlight the config file in the left side, then click on Download in the Configuration file section to store the config.pcc file locally.
  • 7.  RE: Backing up 2930m switch configs
    Posted Sep 26, 2019 08:51 AM
    I saw the Configurations> Management option to download, but wasn't sure if that was it.
