Network Management
Backup-airwave won't revert to being a failover server
  • 1.  Backup-airwave won't revert to being a failover server
    Posted Aug 26, 2015 04:12 PM
    At some point the airwave failover server bacame active.  It kind of went unoticed cause there was never any problem with the primary as far as I know.
    I can't seem to get this failover server to revert back to being a failover.  I've tried 'amp_disable' and rebooted but it still comes back as active.
    Any advice?
    Http and https is allowed between the two is fine, although I've just noticed that icmp is blocked.
  • 2.  RE: Backup-airwave won't revert to being a failover server
    Posted Aug 27, 2015 06:23 AM
    Hi Michael
    failover amps dont automatically revert to 'watching' again after you restore the failed so called "watched" AMP.  Lets call them AMP and AMP-F (failover) to avoid confusion
    first and foremost do you care about the data that the failover AMP-F was collecting while the AMP was down ?
    if yes - then you need to consider restoring a backup of AMP-F onto AMP so that AMP can be as up-to-date as possible before resuming duties. You can do this by either manually invoking backup and taking the fresh backup file, or, just using the latest nightly-backup that is in AMP-F's /var/airwave-backup.
    On AMP-F, assuming you want the latest data
    # amp_backup
    # scp /alternative/databackup.tar.gz   root@AMP:/tmp/databackup.tar.gz
    on AMP
    # amp_restore -d /tmp/databackup.tar.gz
    or, if you dont want to take the backup now, then
    # cd /var/airwave-backup
    # scp nightly_data001.tar.gz   root@AMP:/tmp/databackup.tar.gz
    on AMP
    Now go to next step "if no" below.
    if no - ignore the restore from AMP-F -> AMP, and you need to restore its last backup before it became AMP. This bascially stops AMP-F masquerading as AMP and restores it's regular "running as failover" nightly backup.  These are stored in /var/airwave-backup/watcher/
    on AMP-F
    # amp_restore -d /var/airwave-backup/watcher/nightly_data001.tar.gz
    * note * please make sure to check that anything you are about to restore is 100% correct and the right file
    regards
    -jeff
  • 3.  RE: Backup-airwave won't revert to being a failover server
    Posted Aug 27, 2015 11:00 AM
    Thanks Jeff.  Exactly what I was looking for.
