backup controller
  • 1.  backup controller
    Posted Mar 22, 2015 08:09 PM
    I am in the process of installing a backup controller on my network. I have a master and 14 locals. Any best practices, great instructions or just good advice?
  • 2.  RE: backup controller
    Posted Mar 22, 2015 10:40 PM
    Are you talking about a Backup Master?
  • 3.  RE: backup controller
    Posted Mar 23, 2015 10:57 AM
    Yes I am
  • 4.  RE: backup controller
    Posted Mar 23, 2015 12:26 PM
    You will need to do the following :
    - Make sure that both controllers are on the same AOS version
    - Add all the necessary VLANs to the new controller and if not using Centralize licensing (AOS 6.3 and up) then apply the neccesary licenses to the new controller.
    - Create a VRRP instance and point it to the Management VLAN (for both controllers) - It requires a reboot
    - Point your APs to the VRRP Virtual IP
    - Point your Locals to the new VRRP Virtual IP - Your local controllers will need to reboot after this change
    - Configure Master Redudancy (On both controllers) , based on the priority set on the VRRP will determine which one will be select as the master - Make sure to set the priority higher on the current one
  • 5.  RE: backup controller
    Posted Mar 23, 2015 09:05 PM
    That is great.  Thanks for your time.
