Backup controller not SSID broadcast during failover
  • 1.  Backup controller not SSID broadcast during failover
    Posted Dec 21, 2016 10:50 AM
    I have a MASTER/BACKUP scenario with VRRP configured. The MASTER went down and I could see all AP on the BACKUP controller, however the SSID where not broadcasted and the AP looked as they were not provvisioned (2.5 and 5 ghz leds off)
    (SMPWC2) #
    (SMPWC2) #show ap database
    AP Database
    Name    Group         AP Type  IP Address     Status  Flags  Switch IP     Standby IP
    SMPAP1  Yoti_default  215      10.222.123.6   Down    2      10.222.123.2  0.0.0.0
    SMPAP2  Yoti_default  103      10.222.123.14  Down    2      10.222.123.2  0.0.0.0
    SMPAP3  Yoti_default  215      10.222.123.13  Down    2      10.222.123.2  0.0.0.0
    SMPAP4  Yoti_default  215      10.222.123.12  Down    2      10.222.123.2  0.0.0.0
    SMPAP5  Yoti_default  215      10.222.123.9   Down    2      10.222.123.2  0.0.0.0
    SMPAP6  Yoti_default  215      10.222.123.11  Down    2      10.222.123.2  0.0.0.0
    SMPAP8  Yoti_default  215      10.222.123.10  Down    2      10.222.123.2  0.0.0.0
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed
           I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch
           X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping
           R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP;
           c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2
           u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP
           i = Indoor; o = Outdoor
           M = Mesh node; Y = Mesh Recovery
  • 2.  RE: Backup controller not SSID broadcast during failover
    Posted Dec 21, 2016 10:52 AM
    You need to make sure that the client VLANs on controller 1 are also configured on controller 2, otherwise the APs will not come up.  Type "show log system 50" to see what the problem could be.
  • 3.  RE: Backup controller not SSID broadcast during failover
    Posted Dec 21, 2016 11:00 AM
    The VLAN was in there. I can see the controller took the VRRP's IP but it trown a bunch of errors about config syntax (attached)
    Attachment(s)
    txt
    WCTRL.txt   203 KB 1 version
  • 4.  RE: Backup controller not SSID broadcast during failover
    Posted Dec 21, 2016 11:04 AM
    It looks like you don't have the policy enforcement license installed on that second controller:
    ec 21 15:31:33 :307146:  <DBUG> |cfgm| Parsing the Configuration file to get Snapshot data
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#312::netdestination AllPrivateAddresses
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#317::netdestination googleDNS
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#321::netdestination6 ipv6-reserved-range
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#325::netdestination YotiDHCPservers
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#329::netdestination YotiDNSservers
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#333::netdestination Internet
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#339::netdestination YotiNTP
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#343::netexthdr default
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#356::  any any any  deny
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#359::  any any svc-svp  permit queue high
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#360::  user host 224.0.1.116 any  permit
    Dec 21 15:31:33 :399821:  <DBUG> |cfgm|  Syntax error processing line#367::  user any udp 68  deny
    I would bring the first controller up and enable centralized licensing:  Configuration>Network > Controller > Centralized License Management
  • 5.  RE: Backup controller not SSID broadcast during failover
    Posted Dec 21, 2016 11:07 AM
    Ok,
    I have enabled it. I'll test and I'll let you know. Thanks for your support
