Backup profiles
  • 1.  Backup profiles
    Posted Feb 27, 2012 05:46 PM
    LEt say i got a Aruba 620 Controller
    I get an Aruba 650 Controller
    I want that the new Aruba be the master in this master-local scenario
    Right now the 620 controller is the master
    the 650 got no config its on factory default
    There is a way to backup and restore  just the profiles  and i manually configure the part of the networking so i dont have ton configure the profiles i the new Wireless controller?
    As i wont be able to backup and upload the full config.
    Does anyone know a way to do it otherway besides manually configuring all the thing in the new aruba manually?
  • 2.  RE: Backup profiles
    Posted Feb 27, 2012 05:51 PM
    You could make the 650 a backup master first. That way it gets the config from the 620. Once you are satisfied that everything has synchronized properly, you could then make the 620 a local to the 650.
    That's probably what I would do.
  • 3.  RE: Backup profiles
    Posted Feb 27, 2012 06:28 PM
    Following are the steps to achieve the swap
    1. Create a VRRP instance between 620 and 650 with 620 being the master
    On 620 controller
    vrrp <vrid>
    priority 255 -> this will make sure that this is the master always
    ip address <vrrp ip address>
    vlan <vlan id>
    no shut
    On 650 controller
    The same commands as above but do not enter the command to set the priority
    Default priority is set to 100
    2. Configure master-redundancy between the two controllers 620 - master / 650 - standby
    On both controllers
    On both controllers
    master-redundancy
         master-vrrp <vrrp id>
         peer-ip-address <peer-ip> ipsec <ipsec-key>
    3. Configure database synchronize and set the period to 1 minute, so that it syncs the database every 1 minute.
    database synchronize period 1
    4. Also, sysnchronize the rf-data-plan if you have one
    database synchronize rf-plan-data
    Once the Sync is complete, check the databases on 650 controller to make sure it has all the information.
    After confirmation,
    5. Remove master-redundancy
    6. Remove VRRP
    7. Configure master-ip on the 620 controller and point it to the IP address of 650 controller
    8. Configure local-ip on the 650 controller and point it to the IP address of 620 controller.
  • 4.  RE: Backup profiles
    Posted Feb 27, 2012 06:31 PM
    Thanks for the fast response guys! =)
  • 5.  RE: Backup profiles
    Posted Feb 28, 2012 10:19 AM
    Please mark this thread as solved if it resolved your issue.
    HT
