i have problems with the backup of the switch cisco SG-300, when i try the backup the startup config of the switch, the result is
SNMP Set operation failed.
1. Check that the SNMP parameters are correct.With SNMPv3 adopted, the username,
authentication password, privacy password and privacy mode for the device and the iMC should be the same.
2. Check the MIB style (Execute the display mib-style command. If the MIB style is displayed as new,
but it displays that the node sending the Set request is 2011 after packet capturing, synchronize the device.
Check the MIB style again. If the MIB style is still inconsistent, execute the mib-style [ new | compatible ] command,
and then restart the device.).
3. Error code such as no such name may occur for the Set operation. You need to capture packets to analyze whether such error
occurs in the response received by the device.
4. Device busy, please retry later.
i have the device sync with IMC and when i test the SNMP settings i have the result Device "..."parameters successfully tested.
there any solution for this issue?
#cisco#sg300#ciscosg300#ciscosmallbusiness#ciscosg300#backup#HPEIntelligentManagementCenter#IntelligentManagementCenter#imc#HPIMC
