Bandwidth Contract based on SSID | Aruba 7010 & AP-325
This thread has been viewed 33 times
  • 1.  Bandwidth Contract based on SSID | Aruba 7010 & AP-325
    Posted Mar 21, 2018 03:01 AM
    Aruba 7010 WLC (ArubaOS 6.5.4.3, Build No: 61595)
    we are planning to limit bandwidth based on SSID.
    we have two SSID (SSID--1 for office with psk, SSID-02 for Open internet access).
    we need to limit the maximum upload (10Mbps) & Download (25 Mbps) for SSID-02, how can we achieve this.
  • 2.  RE: Bandwidth Contract based on SSID | Aruba 7010 & AP-325
  • 3.  RE: Bandwidth Contract based on SSID | Aruba 7010 & AP-325
    Posted Mar 21, 2018 03:29 AM
    Thanks zalon0 for quick response.
    we will check this and update you.
  • 4.  RE: Bandwidth Contract based on SSID | Aruba 7010 & AP-325
    Posted Mar 22, 2018 01:01 PM
    hi zalion0, we are looking for bandwidth contrat based on SSID (Maximum bandwidth utilization for Guest SSID is 10 Mbps, its a shared bandwidth for all connected users).
    so as per your advice we need to configure "Proportional BW Allocation" on particular VAP profile (http://www.arubanetworks.com/techdocs/ArubaOS_6_5_4_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/ARM/Traffic_Shaping.htm?Highlight=traffic) am i correct.
  • 5.  RE: Bandwidth Contract based on SSID | Aruba 7010 & AP-325
    MVP EXPERT
    Posted Mar 22, 2018 01:26 PM
    In that case I would suspect you need to configure this under the User Role, so apply a bandwidth contract on a Per Role basis so that the Max Limit is 10Mbps per User Role not Per User.
  • 6.  RE: Bandwidth Contract based on SSID | Aruba 7010 & AP-325
    Posted Mar 22, 2018 01:35 PM
    Sorry pls help me to clear.
    on Post Auth Role we need to apply the bw restriction.
    pls refer the attachemnt.
  • 7.  RE: Bandwidth Contract based on SSID | Aruba 7010 & AP-325
    MVP EXPERT
    Posted Mar 22, 2018 01:37 PM
    Correct, this will be the role that the user is assigned after any form of authentication. Don't forget to test it :)
  • 8.  RE: Bandwidth Contract based on SSID | Aruba 7010 & AP-325
    Posted Mar 22, 2018 01:39 PM
    Thanks man.....
