last person joined: 8 hours ago
Bandwidth Contract not working
  • 1.  Bandwidth Contract not working
    Posted Mar 29, 2012 09:48 AM
    I have the bandwidth contract configured for our guest network, but it doesn't seem to be working.
    The following is the bandwidth contract:
    aaa bandwidth-contract tufts-guest-throttle mbits 5
    Guest users get assigned to the Auth-Tufts-Guest role, which is below:
    user-role Auth-Tufts-Guest
     bw-contract tufts-guest-throttle per-user upstream
     bw-contract tufts-guest-throttle per-user downstream
     session-acl guest-policy
    But using iPerf testing, I was able to send 40 mbits per second. I've verify on the controller that the machine I'm testing with is in the Auth-Tufts-Guest role.
    I there another step I'm missing? Those 2 configuration steps are the only ones I saw in the documentation.
    Bob
  • 2.  RE: Bandwidth Contract not working
    Posted Mar 29, 2012 12:11 PM
    What is the forwarding mode of the VAP used for guests. Currently, bandwidth contracts are supported only for tunnel and decrypt-tunnel mode. There is no support for split-tunnel or bridge mode. Remember, that the traffc will be throttled only at the controller.
    Sathya
  • 3.  RE: Bandwidth Contract not working
    Posted Mar 30, 2012 10:22 AM
    It is configured for tunnel, but I think it was a problem with the iPerf testing, I tried using scp and wget to transfer some files and the bandwidth rate limiting worked fine.
    Bob
