  • 1.  Bandwidth Limit
    Posted Apr 15, 2022 07:53 AM
    Hi Dear
      The bandwidth limit of aruba controller is 40M per user, but the customer's actual test upload and download only reach 20M. Is this normal? Because I tested the upload and download in my own experimental environment to about 30M, but I don't know where the problem is, the channel utilization and load of the AP are normal.
    leo ma
  • 2.  RE: Bandwidth Limit
    Posted May 04, 2022 10:14 AM
    What are the speeds that you get if you disable the bandwidth limits?
    How are you testing the upload and download speed?
  • 3.  RE: Bandwidth Limit
    Posted May 04, 2022 08:25 PM
    hi robers
       1.disable the bandwidth limits speed is normal
       2.sftp to server download and internet speedtest
       3.The AP is 345, the channel utilization is not high, the number of connections is about 25, and there are no high-traffic clients
       4.In the lab test, the speed limit is 40M, and it can run to about 30M, which is the normal speed
       5.I understand that the bandwidth speed limit should be able to run to the maximum,
    leo ma
  • 4.  RE: Bandwidth Limit
    Posted May 05, 2022 09:49 AM
    Then that doesn't sound as expected. Please open a ticket with Aruba Support. They may be able to find out what is causing this.
  • 5.  RE: Bandwidth Limit
    Posted May 09, 2022 09:11 PM
    hi Robers
        thanks
    leo ma
