Bandwidth limit for guests
  • 1.  Bandwidth limit for guests
    Posted Feb 28, 2013 03:05 AM
    Anyone can help me about this:
    In IAPs-105, there is a guest wifi network and a private wifi network. Guest logs in with the self-registration of CP Guest. I would like to limit the bandwidth of the guests but also to preserve a bandwidth for the private wifi.
    I have seen in CPPM an Enforcement Profil "Guest Bandwidth Limit", I think I need to use it but don't understand really how (instead of having read the documentation).
    Someone can give me more details how to do it ?
    Dimitri
  • 2.  RE: Bandwidth limit for guests
    Posted Feb 28, 2013 04:29 AM
    You may configure the QoS on the Instant itself.  If you create a new SSID or edit the current one and click on advanced you can configure this easily. There is an option to use user/radio/airtime bandwith limits.
    From the user guide:
    1. Bandwidth Limits— You can specify three types of bandwidth limits.
      •   Airtime— Indicates the aggregate amount of airtime that all clients on this Network can use to
        send/receive data.
      •   Each user— Indicates the throughput for any single user on this Network. The throughput value is specified in kbps.
      •   Each radio— Indicates the aggregate amount of throughput each radio (some AP models have multiple radios) is allowed to provide for all clients connected to that radio
  • 3.  RE: Bandwidth limit for guests
    Posted Feb 28, 2013 04:42 AM
    Ok thanks but why not doing this on CCPM ?
  • 4.  RE: Bandwidth limit for guests
    Posted Feb 28, 2013 05:54 AM
    What you want is quite simple I would do it on the Instant itself.
    You need to place the QoS on the Instant, on CPPM you could do some kind of accounting (for example the user reach a certain bandiwth then the connection is terminated) or send back some attribute which can be used to place the users to different roles.
  • 5.  RE: Bandwidth limit for guests
    Posted Feb 28, 2013 05:56 AM
    Thanks, I understand better now how to do it.
    Dimitri
