Network Management
Bandwidth Limitation By SSID
  • 1.  Bandwidth Limitation By SSID
    Posted Mar 24, 2016 01:29 PM
    I've deployed a guest network SSID with open security with access to only the internet. I want to limit the bandwidth of this guest network SSID to about 20Mb/s so that the critical SSID's and wired devices aren't impacted by giving away free internet to our guests.
    In short, how do I aggregate the throughput of this SSID and limit it to a certain bandwidth? What is the best way to acheive this? I'm using IAP-215's managed by Aruba Central.
    I see two options for bandwidth limitation. One is per user, which I don't particularly want to do, and the other is by airtime. I don't really understand the documentation on airtime bandwidth limits. Can someone explain this? Is it what I'm looking for?
    Thanks in advance.
  • 2.  RE: Bandwidth Limitation By SSID
    Posted Mar 24, 2016 05:33 PM
    Hi, just enter 20mbps and don't select the user checkbox. Now the total bandwidth is 20mbps per that SSID.
    Cheers
  • 3.  RE: Bandwidth Limitation By SSID
    Posted Mar 24, 2016 05:39 PM
    Got the email that you responded and tried right away!
    The text field doesn't appear until I check the "Each User" text box, and it goes away when it's unchecked. I'm at:
    Wireless Configuration > Advanced Settings > Bandwidth Limits
    Any more suggestions?
  • 4.  RE: Bandwidth Limitation By SSID
    Posted Mar 24, 2016 06:52 PM
    Which version are you running? I have just tested it on the GA version.
  • 5.  RE: Bandwidth Limitation By SSID
    Posted Mar 25, 2016 01:30 PM
    I believe this is the GA build, it says 6.4.4.3-4.2.2.0_53034.
    I'm also doing this through Central as opposed to the instant UI, which one are you using?
    Thanks for your support!
  • 6.  RE: Bandwidth Limitation By SSID
    Posted Mar 25, 2016 03:01 PM
    In the instant webpage
