Bandwidth Quotas on CPPM
  • 1.  Bandwidth Quotas on CPPM
    Posted Aug 21, 2014 08:07 AM
    Hi All
    I have a customer who wants to kick his users off the guest network when they have reached a download cap. I have applied a post auth session enforcement profile that does this fine and disconnects the user. However, this only works when they re-authenticate. So yesterday, whilst on site, I could happily download way more than the 50Mb limit we set, but if I disconnected and reconnected, I would get kicked off.
    How do I make this continually monitor a session and kick them off when they hit 50Mb? I have RADIUS accounting set up properly and the data is being recorded in the Accounting page.
    If I was doing this with RADIUS, then I could reauth regularly and check the bandwidth downloaded that way, without the user seeing a drop but with captive portal, this would mean they would need to re-auth through the portal every time we check the bandwidth figure.
    Any ideas how to get round this?
    Cheers
  • 2.  RE: Bandwidth Quotas on CPPM
    Posted Aug 21, 2014 10:05 AM
    Are you also doing mac-caching?  Perhaps tie into that as well?  Is radius interim accounting also enabled?
  • 3.  RE: Bandwidth Quotas on CPPM
    Posted Aug 21, 2014 12:22 PM
    I have Radius interim accounting set up. We aren't doing mac caching at the moment.
  • 4.  RE: Bandwidth Quotas on CPPM
    Posted Aug 21, 2014 02:29 PM
     Make sure your COA is working. You can check in the logs on the guest side and CPPM to see if is being triggered but there might be some errors.
  • 5.  RE: Bandwidth Quotas on CPPM
    Posted Aug 21, 2014 02:39 PM
    Also make sure in your service that you have the bandwidth limit is in the enforcement.
  • 6.  RE: Bandwidth Quotas on CPPM
    Posted Aug 21, 2014 04:36 PM
    Last time I tried this with 6.3 (didnt work very well...) I had to use a black list repository and it was based on the username (no good for anonymous service).
    I'll try dig out the case nots to see if I an put togther a walk though.
  • 7.  RE: Bandwidth Quotas on CPPM
    Posted Aug 22, 2014 05:36 AM
    I have the badnwidth policy in the enforcement porofile and CoA is working. Maybe I'm missing something but I can't see at what point and how the service would check the bandwidth used except at authentication?
  • 8.  RE: Bandwidth Quotas on CPPM
    Posted Aug 22, 2014 11:37 PM
    you must have interm account turned on also on the NAS device. By default most vendors it is at 10 min intervals.
  • 9.  RE: Bandwidth Quotas on CPPM
    Posted Aug 26, 2014 10:31 AM
    Interim accounting is enabled too!
