Banner MOTD in controller GUI
  • 1.  Banner MOTD in controller GUI
    Posted Apr 20, 2017 04:43 AM
    Hello All,
    Does anybody know an easy way to change the size of the window where the banner MOTD appears in the controller GUI?
    I'm putting a large banner MOTD into the controller, which looks and works great from a CLI point of view. However, due to it's size, you only see the first couple of lines of it, when you start logging in on the GUI.
    Can anything be done about this?
  • 2.  RE: Banner MOTD in controller GUI
    Posted Apr 21, 2017 05:16 AM
    You cannot change the size of that MOTD box.
    It depends also on what you consider large for the MOTD, this is my motd:motd.png
     And that banner has been 'hurt' in some releases (which was apparently by design as UI's are made by designers these days), this is 6.5.1.4, so it may be solved when you upgrade.
    If this still hurts you, please raise a request for enhancement with the specification of what size you do need. You can do that best through your partner or local HPE Aruba SE.
