banner not coming up
  • 1.  banner not coming up
    Posted Aug 23, 2019 10:04 PM
    recently installed a new banner.  We have a aruba 7210 with 6.4.4.10. master and 7030 slave.  banner is coming up on guest wireless on the master controller APs but not on the slave controller APs.  Any help appreciated.
  • 2.  RE: banner not coming up
    Posted Aug 24, 2019 07:43 AM
    Do you mean the guest page?  Do you have an ip address on the guest vlan on the 7030?
  • 3.  RE: banner not coming up
    Posted Aug 25, 2019 04:30 PM
    Yes, the captive portal guest page.  I went back to the master controller APs again. Actually they are not working either.  I get the banner but don't get farther than that.  Just banner, click proceed, then banner comes back up again.  I get ip address.
  • 4.  RE: banner not coming up
    Posted Aug 25, 2019 04:31 PM
    What do you click on to Proceed?
  • 5.  RE: banner not coming up
    Posted Aug 25, 2019 04:33 PM
    A big button that says "proceed".  I know this html captive portal should work because we're using it for our Cisco Wireless, same captive portal.
  • 6.  RE: banner not coming up
    Posted Aug 25, 2019 04:36 PM
    Cisco and Aruba use different methods to signal that a user has authenticated.  You most likely need to  have someone look at the html to see if the proper method is being used.
  • 7.  RE: banner not coming up
    Posted Aug 25, 2019 06:40 PM
    So, I got it to work but after about10 minutes it drops and the wireless icon says "no internet/ open"
