AOS-CX Switch Simulator
Basic Aurba/HPE Question on the Simulator Switch OS...
This thread has been viewed 43 times
  • 1.  Basic Aurba/HPE Question on the Simulator Switch OS...
    Posted Feb 15, 2023 04:49 PM
    Greetings AirHeads!
    I'm new to the form and the new Network Administrator for a city.
    Just curious if the simulator is for the ArubaOS-CX only, or if it is for the ArubaOS-Switch as well?
    For example, managing an Aurba 2930F switch versus an Aruba 6300F switch.
    Thank you much,
    Gordo
  • 2.  RE: Basic Aurba/HPE Question on the Simulator Switch OS...
    Posted Feb 16, 2023 01:43 AM
    The switch simulator is Aruba CX only.
    Arne Opdal
  • 3.  RE: Basic Aurba/HPE Question on the Simulator Switch OS...
    MVP GURU
    Posted Feb 16, 2023 01:27 PM
    Hi, have a look here:
    https://blogs.arubanetworks.com/solutions/explore-aruba-cx-switches-with-the-aos-cx-switch-simulator/
  • 4.  RE: Basic Aurba/HPE Question on the Simulator Switch OS...
    Posted Feb 17, 2023 12:08 PM
    Nice!  That blog is what the executive leaders need to see and ponder as far as future investments go when IT Pros need to migrate from Aruba OS to Aruba CX operating systems (A-OS to A-CXOS).
    Thank you,
    Gordon
  • 5.  RE: Basic Aurba/HPE Question on the Simulator Switch OS...
    Posted Feb 21, 2023 12:30 AM
    you can download the simulator directly from ASP https://asp.arubanetworks.com/
    always go for the latest version
