Basic command output question
  • 1.  Basic command output question
    Posted Jun 14, 2013 06:35 AM
    All,
    This is most probably a simple question re the output of this command:-
    (LHRR1-DC-WIFI1) # show ap association client-mac 00:21:6a:53:e6:0e
    Flags: W: WMM client, A: Active, K: 802.11K client, B: Band Steerable
    PHY Details: HT: High throughput; 20: 20MHz; 40: 40MHz
                 <n>ss: <n> spatial streams
    Association Table
    Name          bssid              mac                auth  assoc  aid  l-int  essid     vlan-id  tunnel-id  phy             assoc. time  num assoc  Flags
    SPcomms-room  d8:c7:c8:f7:e3:59  00:21:6a:53:e6:0e  y     y      11   10     Employee  250      0x112d     a-HT-40sgi-2ss  3m:55s       1          WAB
    00:21:6a:53:e6:0e-d8:c7:c8:f7:e3:59 Stats
    Parameter                            Value
    Channel                              36
    Channel Frame Retry Rate(%)          7
    Channel Frame Low Speed Rate(%)      0
    Channel Frame Non Unicast Rate(%)    8
    Channel Frame Fragmentation Rate(%)  58
    Channel Frame Error Rate(%)          3
    Channel Bandwidth Rate(kbps)         226
    Channel Noise                        88
    Client Frame Retry Rate(%)           0
    Client Frame Low Speed Rate(%)       0
    Client Frame Non Unicast Rate(%)     0
    Client Frame Fragmentation Rate(%)   8
    Client Frame Receive Error Rate(%)   0
    Client Bandwidth Rate(kbps)          6
    Client Tx Packets                    5773
    Client Rx Packets                    1867
    Client Tx Bytes                      609686
    Client Rx Bytes                      1479824
    Client SNR                           29
    Where it shows channel noise 88 and SNR 29, does this equate to RSSI being 59? i.e is  'channel noise' the same as the noise floor? When I run 'inssider' the rssi from that mac to the same AP shows as 50... I am wondering is this just that inssider is unreliabe or I have misconstrued 'channel noise'?
    Thanks.
  • 2.  RE: Basic command output question
    Posted Jun 14, 2013 06:57 AM
    EDIT:  I typed to quickly.
    Channel Noise is the noise floor.
  • 3.  RE: Basic command output question
    Posted Jun 14, 2013 07:11 AM
    Client SNR is in RSSI? Not sure what that means, SNR is the difference between background noise and signal strength which is measure in RSSI on Inssider for example isnt it?
    The measurements are take from Inssider on my laptop which shows my mac's rssi from the AP that is also shown on the command.
    But is 'channel noise' as shown in the command the same as the noise floor measurement? Or am I looking at two different things?
  • 4.  RE: Basic command output question
    Posted Jun 14, 2013 07:24 AM
    Noise is noise floor, correct.
    SNR does = power-noise floor, yes.
    What version of ArubaOS is this and what access point?
  • 5.  RE: Basic command output question
    Posted Jun 14, 2013 07:28 AM
    6.1.3.5
    Ap105.
