basic radio country-code question
  • 1.  basic radio country-code question
    Posted Nov 13, 2014 06:57 AM
    We have 2 wireless 6000 controllers in active active mode with two m3 cards in each chassis with 1100 accesspoints connected, all located in the UK. My manager has recently discovered, that the country setting
    on one of the M3 cards is set to US. The master, standby and three other m3 cards are all set to UK. However, when I look at the list of allowed channels, only UK allowed channels are being used by the APs connected to this card.
    (local-3) #show ap allowed-channels ap-name "example"
    Allowed Channels for AP "example" Country Code "GB" Country "United Kingdom"
    PHY Type Allowed Channels
    802.11g (indoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (indoor) 36 40 44 48 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    802.11g (outdoor) 1 2 3 4 5 6 7 8 9 10 11 12 13
    802.11a (outdoor) 100 104 108 112 116 120 124 128 132 136 140
    802.11g 40MHz (indoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (indoor) 36-40 44-48 52-56 60-64 100-104 108-112 116-120 124-128 132-136
    802.11g 40MHz (outdoor) 1-5 2-6 3-7 4-8 5-9 6-10 7-11 8-12 9-13
    802.11a 40MHz (outdoor) 100-104 108-112 116-120 124-128 132-136
    802.11a (DFS) 52 56 60 64 100 104 108 112 116 120 124 128 132 136 140
    (local-3) #
    Show tech output displays the following :
    show tech
    Hostname is local-3
    System Time:Thu Nov 6 12:23:25 GMT 2014
    No crash information available.
    Reboot Cause: User reboot (Intent:cause:register 78:86:50)
    show syslocation
    Location not configured
    show version
    ArubaOS (MODEL: Aruba6000), Version 6.3.1.8
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2014, Aruba Networks, Inc.
    Compiled on 2014-06-10 at 18:09:03 PDT (build 44205) by p4build
    ROM: System Bootstrap, Version CPBoot 1.3.1.0 (build 35189)
    Built: 2012-09-06 16:06:14
    Built by: p4build@re_client_35189
    show image version
    Partition : 0:0 (/dev/hda1) **Default boot**
    Software Version : ArubaOS 6.3.1.8 (Digitally Signed - Production Build)
    Build number : 44205
    Label : 44205
    Built on : Tue Jun 10 18:09:03 PDT 2014
    Partition : 0:1 (/dev/hda2)
    Software Version : ArubaOS 6.3.1.5 (Digitally Signed - Production Build)
    Build number : 43118
    Label : 43118
    Built on : Tue Apr 8 20:23:43 PDT 2014
    show country
    Country:US
    Model:Aruba6000
    Hardware:Unrestricted
    show country trail
    2014-02-13_07-11-28: Upgrade: domain US
    From the running configuration, we see that the country-code is set to GB, but channel 13 is not available for use on the 2.4Ghz band. The 5.0Ghz availability seem to be correct :
    ap regulatory-domain-profile "default"
    country-code GB
    valid-11g-channel 1
    valid-11g-channel 6
    valid-11g-channel 11
    valid-11a-channel 36
    valid-11a-channel 40
    valid-11a-channel 44
    valid-11a-channel 48
    valid-11a-channel 52
    valid-11a-channel 56
    valid-11a-channel 60
    valid-11a-channel 64
    valid-11a-channel 100
    valid-11a-channel 104
    valid-11a-channel 108
    valid-11a-channel 112
    valid-11a-channel 116
    valid-11a-channel 120
    valid-11a-channel 124
    valid-11a-channel 128
    valid-11a-channel 132
    valid-11a-channel 136
    valid-11a-channel 140
    My first question is a) is the ap regulatory-domain-profile default set when you set the country code and is it applied automatically to the radio profile ? i cant find a radio profile in the configuration that references this profile b) aruba documentation states that you cannot change US or  Israel country setting on an aruba device. How do i change the country setting on this device? c) If I dont change the country setting - does it really matter if my channels are already UK compliant with Ofcom regulator and EU regulator?
    I have referenced the following Aruba docs:
    http://www.arubanetworks.com/techdocs/ArubaOS_63_W​eb_Help/Content/ArubaFrameStyles/1CommandList/ap_r​egulatory_domain_pro.htm
  • 2.  RE: basic radio country-code question
    Posted Nov 13, 2014 08:30 AM
    Please contact TAC.  You have a very unique situation.
  • 3.  RE: basic radio country-code question
    Posted Nov 13, 2014 08:56 AM
    thanks , will do
