AOS-CX Switch Simulator
last person joined: 3 hours ago
Basics: AOS-CX: Pipe (|) support in show commands
This thread has been viewed 22 times
  • 1.  Basics: AOS-CX: Pipe (|) support in show commands
    Posted May 04, 2021 01:42 AM
    AOS-CX Pipe (|) support in show commands
    The pipe (|) command is a CLI session command that filters the output of show show commands according to the criteria specified by the parameter include, exclude, count, begin, or redirect.
    • The pipe (|) command is supported for use with the show command only.
    • You can use multiple pipe commands with a single show
    For example: show running-config | include "vlan" | exclude "vlan2" | count
    • You can use the pipe command with the page
    • Command completion by pressing the Tab key is not supported for pipe
    Happy AOS-CX learning :-)!
    Good day!
    Yash NN
  • 2.  RE: Basics: AOS-CX: Pipe (|) support in show commands
    Posted Mar 15, 2024 06:31 AM
    But it does not work with the command "show logging" or "show event", is that so?
    Something like this:
    show logging -r | include "interface 2/1/19"
