Basics: AOS-CX system capacities and their values!
Below AOS-CX command helps you to find switch/system capacity and also it does provide what is currently configured.
1. show capacities - This cli output provides only configured capacity on the switch.
2. show capacities-status - This cli output provide configured value and also switch max capacity.
6300M-7-VSF# show capacities port-access
System Capacities: Filter Port Access
Capacities Name Value
Maximum number of Clients that can be authenticated on a port 256
Maximum number of Device Profiles allowed to be created on the system 16
Maximum number of Port Access Roles allowed to be created on the system 10000
Maximum number of MAC Address that can be authorized on a port 64
Maximum number of Port Access Role VLAN IDs allowed to be created on the system 1024
Maximum number of Port Access Role VLAN names allowed to be created on the system 50
6300M-7-VSF#
6300M-7-VSF# show capacities-statusSystem Capacities Status
Capacities Status Name Value Maximum
Number of active gateway mac addresses in a system 1 15
Number of aspath-lists configured 0 256
Number of community-lists configured 0 256
Number of BGP neighbors configured across all VRFs 2 256
Number of BGP peer groups configured across all VRFs 1 50
Number of BGP route reflector clients configured across all VRFs 0 256
Number of Access Control Entries currently configured 0 64000
Number of Object Group Entries currently configured 0 2000
Number of Object Groups currently configured 0 1000
Number of Access Control Lists currently configured 0 4000
Number of class entries currently configured 0 8000
Number of classes currently configured 0 1000
Number of policies currently configured 0 4000
Number of policy entries currently configured 0 8000
Number of dynamic VLANs currently learnt using MVRP 0 1024
Number of GBP Role Mappings configured 0 256
Number of IP neighbor (IPv4+IPv6) entries 33 49152
Number of GRE IPv4, "IPv6 in IPv4" and "IPv6 in IPv6" Tunnels currently configured 0 127
Number of IP Directed Broadcast neighbor entries 0 4096
Number of ipsla responder sessions currently configured 0 500
Number of ipsla source sessions currently configured 0 500
Number of IPv4 neighbor(ARP) entries 31 49152
Number of IPv6 neighbor(ND) entries 2 49152
Number of L3 Groups for IP Tunnels and ECMP Groups currently configured 4 2047
Number of L3 Destinations for Routes, Nexthops in ECMP groups and Tunnels currently configured 14 2045
Number of Mirror Sessions currently configured 0 4
Number of Mirror Sessions currently enabled 0 4
Number of MSDP Peers 0 64
Number of MSDP SA Cache entries 0 32768
Number of mstp instances currently configured 1 64
Number of configured NAE agents currently active in the system 1 10
Number of configured NAE monitors currently active in the system 4 130
Number of configured NAE scripts currently active in the system 1 10
Number of OSPFv2 areas configured in the system 1 128
Number of OSPFv2 interfaces configured in the system 2 128
Number of OSPFv3 areas configured in the system 0 128
Number of OSPFv3 interfaces configured in the system 0 128
Number of PBR Action Lists currently configured 0 64
Number of RIP interfaces configured in the system 0 32
Number of RIPng interfaces configured in the system 0 32
Number of prefix-lists configured 0 256
Number of route-maps configured 0 256
Number of RPVST VLANs currently configured 0 254
Number of RPVST Vports currently configured 0 2048
Number of SMARTLINK GROUPS currently configured 0 24
Number of unique GRE IPv4, "IPv6 in IPv4" and "IPv6 in IPv6" tunnel local IPs currently configured 0 127
Number of unique GRE IPv4, "IPv6 in IPv4" and "IPv6 in IPv6" tunnel TTLs currently configured 0 4
Number of active UDLD interface 6 52
Number of routes (IPv4+IPv6) currently configured 20 65536
Number of IPv4 routes currently configured 20 65536
Number of IPv6 routes currently configured 0 61440
Number of VLANs currently configured 13 4094
Number of different IPv4 VRRP virtual router groups configured in a system 0 8
Number of different IPv6 VRRP virtual router groups configured in a system 0 8
Number of IPv4 VRRP virtual addresses configured in a system 0 2048
Number of IPv6 VRRP virtual addresses configured in a system 0 1024
Number of VRRP virtual router groups configured in a system 0 256
Number of VXLAN Interfaces currently configured 1 1
Number of VXLAN L2VNIs currently configured 1 1024
Number of VXLAN L3VNIs currently configured 2 255
Number of VXLAN VNIs currently configured 3 1279
Number of VXLAN VTEPs currently configured 3 512
6300M-7-VSF#
Yash NN
