Wired Intelligent Edge
Basics: CX 6100, 6200, 6300, 6400 - Restore switch to factory default!
This thread has been viewed 198 times
  • 1.  Basics: CX 6100, 6200, 6300, 6400 - Restore switch to factory default!
    Posted May 04, 2021 12:08 AM
    AOS-CX Restore switch to factory default!
    There is no hardware button to reset the switch to factory default settings. The clear button is not there, the reset button will only reboot the switch (short press triggers software reboot, long press triggers hardware reboot). The way to restore switch to factory default is by typing the command "erase all zeroize" at console.
    Please refer AOS-CX Fundamental guide to know more details:
    AOS-CX 10.06 Fundamentals Guide 6300, 6400 Switch Series
    Good day!
    Yash NN
  • 2.  RE: Basics: CX 6100, 6200, 6300, 6400 - Restore switch to factory default!
    Posted May 05, 2021 04:38 AM
    And how do you do if you have forgotten the login password to access console/cli ?
    Laurent from Brest / France
    Network Engineer
  • 3.  RE: Basics: CX 6100, 6200, 6300, 6400 - Restore switch to factory default!
    Posted May 05, 2021 05:51 AM
    Whitehawk29FR  you would need to boot and go to Service OS (option 1 at boot)...from which you could then change the password
    Kamal Takodra
  • 4.  RE: Basics: CX 6100, 6200, 6300, 6400 - Restore switch to factory default!
    Posted yesterday
    During Reboot choose Option 0 , and then type "erase zeroize"
