Root access via CLI is locked from 8.2.4 version. Please work with TAC to get to root access and run the script.
Original Message:
Sent: Sep 27, 2023 01:44 PM
Subject: Batch creation of folders on Airwave
Is there a way to run the create_folders_from_csv.pl script on 8.2.15.1?
Original Message:
Sent: Dec 15, 2016 12:13 PM
If you're on 8.2.2.1 or 8.2.3
then the path is now root/git/mercury/scripts
we made the change from subversion to git recently
the script should still work the same
make sure that your csv file has the header row of Top_folder,new_folder
