Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
  • 1.  Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 07:27 PM
    Today i tried upgrading the RAP109 i got at home...
    Whenever i upgrade it to the instant version 4, the WLAN does not go up.. the config is there is fine but the leds of 2.4 and 5.0 keep on Orange... I had to rollback it...
    Tried again with the default config as i got many things configured in there.. but still same isssue...
    Not sure if it just with RAP 109 but be prepared taking the Backup, in case you have to roll back like i had to do.  Or test with one instant before.
    Going to open a support ticket with tac.
    Cheers
    Carlos
  • 2.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 07:53 PM
    Is there anything in the logs?
  • 3.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 07:57 PM
    Collin actually i didnt check i just rollback... i had to use the internet so i didnt troubleshoot at all...
    I can tell you that  before that idid my backup like always.  Then upgraded it didnt work...
    I did clearos and also factory_reset
    Then the AP came up again normally.  I tried upgrading again with no config.  And happened the same... so i just rolled back and uploaded the backup...
    Sorry  i didnt look at the logs.
    What i was thinking was opening a case tomorrow and trry again with the tac.
    Cheers
    Carlos
  • 4.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 08:05 PM
    I upgraded two days ago and worked with no issues , but I am using an IAP 135
    It took a little bit longer to reboot after the upgrade but other than is working great.
  • 5.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 08:07 PM
    yes  it took a lil longer... but i waited for 10 mins after the cli launched and still the leds on both bands were orange....
    Maybe is just a bug related with the rap 109... ill just open a case tomorrow to see what happens :)
    Cheers
    Carlos
  • 6.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    RAP3 and IAP-93 working without issue as well.
    Did you use the Pegasus build Carlos?
  • 7.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 08:09 PM
    Yep i used the pegasus one... the pegasus is for rap 109 and ap 115....
    Cheers
    Carlos
  • 8.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 08:47 PM
    Carlos,
    If you can upgrade and get me the tech support, that will be useful.
  • 9.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 08:50 PM
    give me 2 hours im donwloading something :) ill upgrade it and give you the tech support after the upgrade
    Cheers
    Carlos
  • 10.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 09:35 PM
    It was the regulatory domain like Collin told me on the email!
    That was the issue...
    My country code worked for early version but it doesnt work for this new version...
    Cheers
    Carlos
  • 11.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 09:38 PM
    What country code were you using?
  • 12.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 10:10 PM
    Panama
  • 13.  RE: Be careful before upgrading to Instant 4.0(6.3.1.1-4.0.0.0)
    Posted Nov 20, 2013 10:24 PM
    I actually didnt think of that becasue on the controller the APS goes to air monitor... this didnt go to air monitor... it were like if the bands were disable, like when i put 5ghz only the 2.4ghz goes orange led.
    Cheers
    Carlos
