Best application AP 105 or 115
  • 1.  Best application AP 105 or 115
    Posted Apr 23, 2014 03:45 PM
    I need help choosing between the 105 and 115 for a house with fat concrete walls where the AP will be wall mounted.
    If there another AP better suited for my application please let me know.
    Thanks...
  • 2.  RE: Best application AP 105 or 115
    Posted Apr 23, 2014 06:23 PM
    Both APs are design with built-in antennas that are optimized for horizontal ceiling mounting orientation. I would suggest you consider mounting the AP horizontally or go with AP114 with external omni directional antenna.
    - AP110 series is 3x3:3 which means you can get up to 450Mbps.
    - AP 105 is 2x2:2 which means you can get up to 300Mbps.
    If you ask me I would go with AP110 series.
    Thank you.
  • 3.  RE: Best application AP 105 or 115
    Posted Apr 23, 2014 07:44 PM
    Thank you.
    One more question, what if the connection is 150Mbps. Does the 110 have any advantages over the 105 other than the speed?
  • 4.  RE: Best application AP 105 or 115
    Posted Apr 23, 2014 08:54 PM
    It depends on the client device. Do you know which client are you trying to connect? Is it an smart device or a laptop which model of NIC card does it have.
    As AP-110 has 3 spatial stream it will definitely provide more throughput. It's like having 3 lanes on the highway compare to two lanes.
    Hope this clarifies...
    Thank you.
  • 5.  RE: Best application AP 105 or 115
    Posted Apr 23, 2014 09:53 PM
    Appritiate it. Thank you
