Best auth mode
  • 1.  Best auth mode
    Posted Jun 06, 2016 05:33 AM
    Hi
    i have an new building with some med carts  , and i need to configure my 7205 controller with my AP 205
    i would like to know what is the recommended way of authentication and also the easiest to configure
    ( in the past i had cert server and radius...it wasnt easy to manage it , this is why i am looking for other way to connect
    thanks
    TK
  • 2.  RE: Best auth mode
    Posted Jun 06, 2016 05:36 AM
    You should use whatever authentication methods are recommended by the Med Cart manufacturer.  What is the operating system?
  • 3.  RE: Best auth mode
    Posted Jun 06, 2016 05:51 AM
    Hi
    80% are windows 7 and few still old XP machines , all of them are at workgroup , not join to a domain
    if i would like to use LDAP do i need another server like radius , or i could use only the controler ?
    thanks
  • 4.  RE: Best auth mode
    Posted Jun 06, 2016 05:59 AM
    If they are not joined to the domain, it is going to be painful to configure all of those computers.  You probably can only do WPA2-AES-PSK
  • 5.  RE: Best auth mode
    Posted Jun 06, 2016 07:49 AM
    Hi
    so the only way is with user/password ? (local db)
  • 6.  RE: Best auth mode
    Posted Jun 06, 2016 07:53 AM
    How many carts do you have?  It is difficult to configure carts for username and password authentication if they are not part of a domain...
  • 7.  RE: Best auth mode
    Posted Jun 06, 2016 09:34 AM
    i have a round 100 carts
    its not a problem to get one by one , i will do it step by step
    i saw that i can run LDAP , if i will create each cart a user on the AD do i need anything more ?
  • 8.  RE: Best auth mode
    Posted Jun 06, 2016 09:39 AM
     Using LDAP will force you to install custom software on each cart.  I would engage a consultant to tell you the best way to deploy all of your carts.  I can tell you what you should do, but a consultant will work directly with you to make sure that everything is considered.
  • 9.  RE: Best auth mode
    Posted Jun 06, 2016 05:38 AM
    Also, consider working with your Aruba partner to design an authentication architecture that works across platforms and is easy to manage.
