Hi everyone!
I'm pretty curious to see how you best practice manage your switches in Aruba Central. I really like the monitoring tools in Central, but configuring switches, I find it quite a hassle compared to just executing the commands via SSH.
I now manage them through Template Groups, but I can't find an easy and fast way to configure for each specific switch his vlan ports. For VLAN 1 there is a variable, but for other VLAN's I don't see an easy option to create variables myself? And also, that's pretty complicated instead of just running commands?
What I did now, is for each switch I have, I created an IF-Statement on serial number so that I have a block with all vlans and ports for each switch.. but is there a better way?
I would like to have option to configure it locally (SSH) and that the switch would sync config with cloud. But guess that's not possible for now.
UI-configuration is still also not very practical.. For example giving a management IP in different VLAN lacks etc..
So I'm very curious how you manage your switches in Central?
Thanks a lot!
Cedric De Witte
