last person joined: 7 hours ago
Best practice for multi-use ports and VLAN's
  • 1.  Best practice for multi-use ports and VLAN's
    Posted Jul 17, 2018 04:01 PM
    I am sure this has been done before and is possible but I am unsure of what is the best way to configure it or where I can get the configure. The scenario is for wired ports on a edge switch, user with windows laptops have 802.1x through GPO, while Phones and Printers can be used on the ports.
    I want to configure all ports the same so IMAC doesn't require port configs
    When a phone is plugged in, it will fail 802.1x but be in the Clearpass MAB and the VLAN changed phone VLAN X tagged and untagged Data VLAN Y
    When a printer is plugged in, it will fail 802.1x and MAB list will send Printer VLAN Z
    When a laptop is plugged in, it will pass 802.1x and VLAN A Corp Network assigned.
    How would i best configure this, configure the port for the phone, and on clearpass enforcement policy assign a VLAN for the printer and Corp?
  • 2.  RE: Best practice for multi-use ports and VLAN's
    Posted Jul 17, 2018 04:02 PM
    Did you read the ClearPass Solution Guide for Wired Policy Enforcement? Colorless ports are covered in great detail.
  • 3.  RE: Best practice for multi-use ports and VLAN's
    Posted Jul 17, 2018 04:49 PM
    Thanks Tim,
    I hadn't but I will
