last person joined: 10 hours ago
Best Practices for Configuring 802.1X and MAC Authentication with Aruba Switches and ClearPass, Considering Unmanaged Switches
This thread has been viewed 32 times
  • 1.  Best Practices for Configuring 802.1X and MAC Authentication with Aruba Switches and ClearPass, Considering Unmanaged Switches
    Posted Mar 19, 2024 05:08 PM
    Hello Community
    After recently upgrading our network with Aruba 6200 Access Switches and 6300 Core Switches, managed via Aruba Central with the Multi-Edit feature, we're integrating ClearPass to implement both 802.1X (Dot1X) and MAC Authentication to enhance our network's security and access control.
    Our network configuration is somewhat unique due to the inclusion of unmanaged switches at several workstations. This setup has necessitated specific adjustments to our managed switch configurations to accommodate the connectivity and authentication requirements of multiple devices through a single port. Specifically, we have set the client limit on our access switches to 20 (aaa authentication port-access client-limit 20) to manage the devices connected via unmanaged switches effectively.
    Despite this adjustment, we're encountering challenges with inconsistent authentication behaviors, particularly where Dot1X and MAC Authentication are concerned. Below is our current configuration for the managed switches:
     no shutdown
    no routing
    description Access
    vlan access xxx
    spanning-tree bpdu-guard
    spanning-tree port-type admin-edge
    loop-protect
    rate-limit broadcast 1000 kbps
    rate-limit multicast 10000 kbps
    aaa authentication port-access allow-lldp-bpdu
    port-access onboarding-method concurrent enable
    port-access security violation action shutdown auto-recovery enable
    port-access security violation action shutdown recovery-timer 600
    port-access allow-flood-traffic enable
    aaa authentication port-access dot1x authenticator
        reauth
        eapol-timeout 7
        initial-auth-response-timeout 20
        max-eapol-requests 3
        max-retries 3
        reauth-period 200
        discovery-period 7
        enable
    aaa authentication port-access mac-auth
        cached-reauth
        reauth
        reauth-period 200
        enable
    Given the mixed environment of managed and unmanaged switches, we're seeking insights on optimizing our setup to ensure consistent and secure authentication across all devices. Is there a better approach to handling authentication in such a scenario, or does the presence of unmanaged switches necessitate a reconsideration of our network design?
    We appreciate any shared experiences, advice, or configuration recommendations that could help us improve our network's reliability and security.
    Thank you for your valuable insights
    Kind Regards
    Dia
  • 2.  RE: Best Practices for Configuring 802.1X and MAC Authentication with Aruba Switches and ClearPass, Considering Unmanaged Switches
    Posted Mar 29, 2024 12:23 PM
    The use of unmanaged switches is not recommended and it may indeed affect the reliability as a physical link coming up (and going down on a disconnect) helps the clients and switch to synchronize the 802.1X and MAC Authentication, and the failover between those.
    It would really help to get clear what behavior you see more specific, what are the conditions when you get clients authenticated in a different state than desired, and from there see if changing the port-access timers/parameters can help to resolve those conditions. I don't know a universal good working configuration for this situation. Working with your Aruba Partner or TAC may be useful.
