Best practices for logging on Aruba AOS8 Controllers
This thread has been viewed 31 times
  • 1.  Best practices for logging on Aruba AOS8 Controllers
    Posted May 10, 2023 02:17 AM
    Hi all,
    Are there any best practices that will suit most environments for logging on Aruba AOS Mobility Conductors and Controllers? Specifically want to know what categories and severity levels are safe to configure.
    Don't want to miss anything, and don't want to be spammed too hard either.
    I've been doing trial and error but struggling to find a good balance.
    Brett V
  • 2.  RE: Best practices for logging on Aruba AOS8 Controllers
    Posted May 10, 2023 08:39 AM
    If you are not looking for anything specific, the warnings classification is default is the best for most circumstances.  Only if something specific is being looked for, should it ever be more verbose.
  • 3.  RE: Best practices for logging on Aruba AOS8 Controllers
    Posted May 11, 2023 01:50 AM
    Thanks Colin,
    ChatGPT4 mostly agrees with you :-)
    (config) # logging level warnings network subcat all
    (config) # logging level warnings security subcat all
    (config) # logging level warnings system subcat all
    (config) # logging level informational user subcat all
    (config) # logging level warnings wireless subcat all
    (config) # logging level warnings firewall subcat all
    (config) # logging level warnings dhcp subcat all
    (config) # logging level warnings ids subcat all
    (config) # logging level warnings vpn subcat all
    (config) # logging level warnings ha subcat all
    (config) # logging level warnings mgmt subcat all
    (config) # logging level warnings mesh subcat all
    (config) # logging level warnings dot1x subcat all
    (config) # logging level warnings radius subcat all
    (config) # logging level warnings l2tp subcat all
    (config) # logging level warnings l3vpn subcat all
    (config) # logging level warnings web subcat all
    (config) # logging level warnings tunnel subcat all
    (config) # logging level warnings aaa subcat all
    (config) # logging level warnings airgroup subcat all
    Brett V
