best practices for VirtualRF?
  • 1.  best practices for VirtualRF?
    Posted Sep 03, 2015 12:20 PM
    Hi... I keep finding things out about VRF in bits and pieces... about important things--
    like
    current gridsize relative to suggested gridsize
    the "fu" of drawing in wall material type... and whether you should or not (seems like there's no consensus with Aruba support)
    importing file tricks-- how to get a clean, sharp blueprint imported
    Just wondering why there isn't a separate board/forum for gathering all those tips/tricks together.
  • 2.  RE: best practices for VirtualRF?
    Posted Sep 05, 2015 12:05 AM
    We usually rotate our floorplans so north is up, pull each flloor into gimp along with a google satellite view for the roof, scale/rotate/line them up layer by layer to the google map, then crop all to the same size.  Then after import and measuring, to place the origin put a little sticker on the screen and line it up to that.  That way your floor-to-floor RF bleed is dead on.
    Also don't spend a huge amount of time zooming in to make wall corners meet -- just let them overlap a bit.  The agorithm won't care about an imaginary 6" flange.
  • 3.  RE: best practices for VirtualRF?
    Posted Sep 08, 2015 09:47 AM
    "put a little sticker on the screen and line it up to that"
    Haha, that's awesome man. Resourceful.
    Aruba--- maybe that's an indicator that your software is lacking, when people are putting stickers on the screen.
  • 4.  RE: best practices for VirtualRF?
    Posted Sep 08, 2015 09:51 AM
    It's a free tool. If you need something more robust, consider Ekahau.....
  • 5.  RE: best practices for VirtualRF?
    Posted Sep 08, 2015 10:18 AM
    Can Ekahau be used in lieu of VRF?
    Or is it something one uses to optimize floorplans before importing into VRF?
  • 6.  RE: best practices for VirtualRF?
    Posted Sep 08, 2015 10:20 AM
    The Ekahau planner tool can be used for predictive analysis instead of
    VisualRF if it's not meeting your needs.
  • 7.  RE: best practices for VirtualRF?
    Posted Sep 08, 2015 11:37 AM
    The ability to create custom wall types in the standalone would be handy.  I put a feature request in for that a while ago.
    The devil is really in the detail.  It is really worth taking the time to put the walls in and setting the correct ap type and power levels.  It makes the planning survey much more accurate and professional.  Typicall I would wrap the outside walls in concrete.
