Aruba Apps
  • 1.  Best recommended iap for home network
    Posted Jan 21, 2023 03:41 PM
    Hi team,
    We have a VVIP customer using AP205H from past 5 years . Now they are facing some network issues like freezing during video call .
    I have checked the configuration and cables everything is looking good  but AP 205H support till 6.5 image version only.
    Now they have asked me to suggest upgrade / replacement of the devices, if any. And want complete recommend settings of the IAP cluster.
    If anyone can suggest me which AP would be better and what are the advantages will they get with replacement of 205H.
  • 2.  RE: Best recommended iap for home network
    Posted Jan 22, 2023 10:31 AM
    The easiest path would be to upgrade to an IAP-505H
    https://www.arubanetworks.com/en-ca/products/wireless/access-points/remote-hospitality-access-points/500h-series/
  • 3.  RE: Best recommended iap for home network
    Posted Jan 22, 2023 11:00 AM
    Hi ,
    Thanks for your reply.
    Does AP205H has Wi-Fi 6 capabilities?
    Thanks & Regards,
    Shivam Ojha
    Orbit Techsol (W) PVT LTD
    Mob:7743901736 Email: shivam.ojha@orbitindia.net
  • 4.  RE: Best recommended iap for home network
    Posted Jan 22, 2023 11:40 AM
    It does not...it's also EOL/EOS.
    https://www.arubanetworks.com/assets/ds/DS_AP205H.pdf
