best Settings for 802.11g Connectivity
  • 1.  best Settings for 802.11g Connectivity
    Posted Jan 13, 2017 02:28 AM
    Mallikarjun
  • 2.  RE: best Settings for 802.11g Connectivity
    Posted Jan 13, 2017 04:11 AM
    Hi!
    I think you need to be a little more specific than that if you want anyone to be able to assist you :)
    Please provide some context of what you´re trying to do.
    Cheers,
  • 3.  RE: best Settings for 802.11g Connectivity
    Posted Jan 13, 2017 04:25 AM
    Hi Christoffer
    In one of our client place they deployed ap-225 model and they are getting lattency while roaming with the 802.11b/g devices but 802.11n devices working fine.So i need to know any best practices for the driver settings, or else we need to update the drivers?
    Mallikarjun
  • 4.  RE: best Settings for 802.11g Connectivity
    Posted Jan 13, 2017 04:34 AM
    Are the 802.11n devices also connecting on 2,4 ghz or are they using 5ghz? Then perhaps your issue is a noisy 2,4ghz environment. Try verifying your radio planning with placements/shut down of some 2,4ghz radios and lowering of Tx power to minimize co-channel interference.
    Also updating the client drivers is a good thing to do to see if it brings any improvements.
    Cheers,
  • 5.  RE: best Settings for 802.11g Connectivity
    Posted Jan 13, 2017 05:08 AM
    Hi ,
    11n devices connecting via 5ghz.
    Thank you..
  • 6.  RE: best Settings for 802.11g Connectivity
    Posted Jan 13, 2017 06:33 AM
    @Mallikarjun wrote:
    Hi Christoffer
    Mallikarjun
    You should adjust the wifi first, before considering doing anything with the drivers.  Please PM me your email address so we can look at your tech support.
