Best way to consolidate licenses?
  • 1.  Best way to consolidate licenses?
    Posted May 07, 2013 03:52 PM
    We originally started with a 500 device license.  A while back we added 50.  I believe that was before Aruba had the option to consolidate licenses on the licensing site.  I ended up wiping out the original 500 and just having a 50 license.having to call TAC and eventually they ended up creating a new license for 550 devices.
    I think another issue may be the way the reseller(s) creates the order.  Sometimes they use "And" in the company name and other times they use "&"
    Now I'm ready to add another 50 device license.  I don't believe I ever received a certificate ID from the previously consolidated 550 license, so I don't think I can use that feature on the site.  Actually don't even see a certificate ID from our original order, just a license key via email.  I do have the certificate ID from the subsequent 50 license purchases.
    What's the best way to get my server up to 600 licenses without creating any downtime or loss of functionality?
  • 2.  RE: Best way to consolidate licenses?
    Posted May 07, 2013 05:13 PM
    As far as I know the only way to do this is to contact TAC and have them merge the licenses.
  • 3.  RE: Best way to consolidate licenses?
    Posted May 07, 2013 05:18 PM
    Thanks.  I'll email tomorrow and hopefully won't take too long to get it taken care of.
  • 4.  RE: Best way to consolidate licenses?
    Posted May 07, 2013 05:50 PM
    You can consolidate or split AirWave license keys using https://licensing.arubanetworks.com
    1. Login
    2. My AirWave tab
    3. Consolidate AirWave licenses
    This requires knowing the certificate IDs for your licenses.  Otherwise you'll have to follow the TAC route.
  • 5.  RE: Best way to consolidate licenses?
    Posted May 07, 2013 08:10 PM
    Unless TAC has done a merge for you in the past.
    So far we haven't been able to get the merged license into the license management site.
    By "we" I mean "me asking TAC" of course ;)
  • 6.  RE: Best way to consolidate licenses?
    Posted May 13, 2013 01:25 PM
    Correct, but the merge via TAC was a painless procedure - 2 emails and it was finished.
  • 7.  RE: Best way to consolidate licenses?
    Posted May 14, 2013 03:11 PM
    yep, that is my experience also, TAC handles this superb.
