Comware
BFD on HP 8206zl and HP 5406zl
  • 1.  BFD on HP 8206zl and HP 5406zl
    Posted May 21, 2013 02:15 AM
    Is BFD supported on these two platforms? I'm trying to find out for a client out at a remote site to advise whether they need to implement OSPF or whether static routes with BFD will suffice. I can't find anything about it in the doco.
    Cheers
    James
    #staticrouting
    #HP
    #8200
    #8206zl
    #5400
    #5406z
    #BFD
  • 2.  RE: BFD on HP 8206zl and HP 5406zl
    Posted May 21, 2013 02:25 AM
    Hi James,
    I certainly can't recall seeing anything about BFD support in the 5400 series, but my memory could be failing me... ;-)
    If a search of the documentation doesn't show anything, that's probably all the answer you need.
