Wired Intelligent Edge
BFD, OSPF and Disabling ICMP
  • 1.  BFD, OSPF and Disabling ICMP
    Posted Dec 07, 2021 05:26 AM
    I am looking into BFD for OSPF peers on OS-CX and the 10.08 High Availability Guide Page 18
    Configuring BFD For OSPFv2
    Prerequisites
    -OSPFv2 must be enabled.
    -ICMP must be disabled.
    I don't understand why ICMP needs to be disabled, nor how to disable it.
    Can anybody shed some light on this one?
    Link to guide
    https://www.arubanetworks.com/techdocs/AOS-CX/10.08/PDF/high_availability.pdf
    Arubanetworks remove preview
    View this on Arubanetworks >
    Thanks, AP.
    Andrew Partridge
  • 2.  RE: BFD, OSPF and Disabling ICMP
    MVP GURU
    Posted Dec 07, 2021 07:46 AM
    BFD operates by sending its control packets to itself, sourcing from itself. This is to test the forwarding plane of the remote router; assuming that if it can route the packet back, it has an operational forwarding plane. However, by default the remote router will issue an ICMP redirect message informing the sending router that it has a more optional path (via itself). By nature, it makes no sense to send a packet to a remote router only for that router to send it back again, but since this is actually exactly what we want to do with BFD, we need to disable these ICMP redirect messages on BFD-enabled interfaces. This is to avoid a high CPU utilization on the remote router. BFD will work without disabling ICMP redirects, and might not be a problem if you have only a few BFD peers, but at some point the CPU will be too busy generating the ICMP redirects. This is why ICMP redirects really should be disabled.
    Dustin Burns
    Lead Mobility Engineer @WEI
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2021
  • 3.  RE: BFD, OSPF and Disabling ICMP
    Posted Dec 08, 2021 04:23 AM
    Thanks Dustin,
    That makes sense, the documentation wasn't clear it was ICMP redirect to disable.
    Is this only applicable to echo mode, and not in Asynchronous mode?
    Andrew Partridge
  • 4.  RE: BFD, OSPF and Disabling ICMP
    Posted Dec 08, 2021 04:08 AM
    IN addition, to complete the answer, the how to disable it is:
    no ip icmp redirect
    Vincent Giles
