Comware
  • 1.  BGP4-MIB partial output on HPE 5510/5940/10508 (Comware 7)
    Posted Sep 29, 2017 06:53 PM
    Good day, experts!
    Recently faced strange problem with our 5510/5940/10508 boxes - BGP4-MIB shows partial output. When i made snmpwalk over this MIB, switches show me their BGP Version (oid 1.3.6.1.2.1.15.1), ASN (oid 1.3.6.1.2.1.15.2) and RID (oid 1.3.6.1.2.1.15.4) only. No other information at all. No peers, no peer states, no prefixes, etc...
    We are using INTER-AS options A and B on this devices, so my question: how can we obtain detailed information about BGP sessions via SNMP?
    Thanks in advance!
    #10508
    #comware7
    #BGP4-MIB
    #5510
    #snmp
    #5940
  • 2.  RE: BGP4-MIB partial output on HPE 5510/5940/10508 (Comware 7)
    Posted Oct 02, 2017 05:16 AM
    MIB OIDs .1.3.6.1.2.1.15 related (as of latest MIB V9 for Comware here) can be easily found, as example:
    .1.3.6.1.2.1.15
    bgp MODULE-IDENTITY
      -- FROM	BGP4-MIB
      DESCRIPTION	"The MIB module for the BGP-4 protocol.
                         Copyright (C) The Internet Society (2006).  This
                         version of this MIB module is part of RFC 4273;
                         see the RFC itself for full legal notices."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) 15 }
    .1.3.6.1.2.1.15.0
    bgpNotification OBJECT-TYPE
      -- FROM	BGP4-MIB
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) 0 }
    .1.3.6.1.2.1.15.0.1
    bgpEstablishedNotification NOTIFICATION-TYPE
      -- FROM	BGP4-MIB
      OBJECTS	{ bgpPeerRemoteAddr, bgpPeerLastError, bgpPeerState }
      DESCRIPTION	"The bgpEstablishedNotification event is generated
                         when the BGP FSM enters the established state.
                         This Notification replaces the bgpEstablished
                         Notification."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpNotification(0) 1 }
    .1.3.6.1.2.1.15.0.2
    bgpBackwardTransNotification NOTIFICATION-TYPE
      -- FROM	BGP4-MIB
      DESCRIPTION	"The bgpBackwardTransNotification event is
                         generated when the BGP FSM moves from a higher
                         numbered state to a lower numbered state.
                         bgpBackwardsTransition Notification."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpNotification(0) 2 }
    .1.3.6.1.2.1.15.1
    bgpVersion OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	OCTET STRING (1..255)
      MAX-ACCESS	read-only
      STATUS	current
      DESCRIPTION	"Vector of supported BGP protocol version
                         numbers.  Each peer negotiates the version
                         from this vector.  Versions are identified
                         via the string of bits contained within this
                         object.  The first octet contains bits 0 to
                         7, the second octet contains bits 8 to 15,
                         and so on, with the most significant bit
                         referring to the lowest bit number in the
                         octet (e.g., the MSB of the first octet
                         refers to bit 0).  If a bit, i, is present
                         and set, then the version (i+1) of the BGP
                         is supported."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) 1 }
    .1.3.6.1.2.1.15.2
    bgpLocalAs OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	Integer32 (0..65535)
      STATUS	current
      DESCRIPTION	"The local autonomous system number."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) 2 }
    .1.3.6.1.2.1.15.3
    bgpPeerTable OBJECT-TYPE
      -- FROM	BGP4-MIB
      MAX-ACCESS	not-accessible
      STATUS	current
      DESCRIPTION	"BGP peer table.  This table contains,
                         one entry per BGP peer, information about the
                         connections with BGP peers."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) 3 }
    .1.3.6.1.2.1.15.3.1
    bgpPeerEntry OBJECT-TYPE
      -- FROM	BGP4-MIB
      STATUS	current
      INDEX		{ bgpPeerRemoteAddr }
      DESCRIPTION	"Entry containing information about the
                         connection with a BGP peer."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) 1 }
    .1.3.6.1.2.1.15.3.1.1
    bgpPeerIdentifier OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	IpAddress
      STATUS	current
      DESCRIPTION	"The BGP Identifier of this entry's BGP peer.
                         This entry MUST be 0.0.0.0 unless the
                         bgpPeerState is in the openconfirm or the
                         established state."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 1 }
    .1.3.6.1.2.1.15.3.1.2
    bgpPeerState OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	INTEGER {idle(1), connect(2), active(3), opensent(4), openconfirm(5), established(6)}
      STATUS	current
      DESCRIPTION	"The BGP peer connection state."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 2 }
    .1.3.6.1.2.1.15.3.1.3
    bgpPeerAdminStatus OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	INTEGER {stop(1), start(2)}
      MAX-ACCESS	read-write
      STATUS	current
      DESCRIPTION	"The desired state of the BGP connection.
                         A transition from 'stop' to 'start' will cause
                         the BGP Manual Start Event to be generated.
                         A transition from 'start' to 'stop' will cause
                         the BGP Manual Stop Event to be generated.
                         This parameter can be used to restart BGP peer
                         connections.  Care should be used in providing
                         write access to this object without adequate
                         authentication."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 3 }
    .1.3.6.1.2.1.15.3.1.4
    bgpPeerNegotiatedVersion OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	Integer32
      STATUS	current
      DESCRIPTION	"The negotiated version of BGP running between
                         the two peers.
                         This entry MUST be zero (0) unless the
                         established state.
                         Note that legal values for this object are
                         between 0 and 255."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 4 }
    .1.3.6.1.2.1.15.3.1.5
    bgpPeerLocalAddr OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	IpAddress
      STATUS	current
      DESCRIPTION	"The local IP address of this entry's BGP
                         connection."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 5 }
    .1.3.6.1.2.1.15.3.1.6
    bgpPeerLocalPort OBJECT-TYPE
      -- FROM	BGP4-MIB
      STATUS	current
      DESCRIPTION	"The local port for the TCP connection between
                         the BGP peers."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 6 }
    .1.3.6.1.2.1.15.3.1.7
    bgpPeerRemoteAddr OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	IpAddress
      STATUS	current
      DESCRIPTION	"The remote IP address of this entry's BGP
                         peer."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 7 }
    .1.3.6.1.2.1.15.3.1.8
    bgpPeerRemotePort OBJECT-TYPE
      -- FROM	BGP4-MIB
      STATUS	current
      DESCRIPTION	"The remote port for the TCP connection
                         between the BGP peers.  Note that the
                         objects bgpPeerLocalAddr,
                         bgpPeerLocalPort, bgpPeerRemoteAddr, and
                         bgpPeerRemotePort provide the appropriate
                         reference to the standard MIB TCP
                         connection table."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 8 }
    .1.3.6.1.2.1.15.3.1.9
    bgpPeerRemoteAs OBJECT-TYPE
      -- FROM	BGP4-MIB
      STATUS	current
      DESCRIPTION	"The remote autonomous system number received in
                         the BGP OPEN message."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 9 }
    .1.3.6.1.2.1.15.3.1.10
    bgpPeerInUpdates OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	Counter32
      STATUS	current
      DESCRIPTION	"The number of BGP UPDATE messages
                         received on this connection."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 10 }
    .1.3.6.1.2.1.15.3.1.11
    bgpPeerOutUpdates OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	Counter32
      STATUS	current
                         transmitted on this connection."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 11 }
    .1.3.6.1.2.1.15.3.1.12
    bgpPeerInTotalMessages OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	Counter32
      STATUS	current
      DESCRIPTION	"The total number of messages received
                         from the remote peer on this connection."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 12 }
    .1.3.6.1.2.1.15.3.1.13
    bgpPeerOutTotalMessages OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	Counter32
      STATUS	current
      DESCRIPTION	"The total number of messages transmitted to
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 13 }
    .1.3.6.1.2.1.15.3.1.14
    bgpPeerLastError OBJECT-TYPE
      -- FROM	BGP4-MIB
      SYNTAX	OCTET STRING (2)
      STATUS	current
      DESCRIPTION	"The last error code and subcode seen by this
                         peer on this connection.  If no error has
                         occurred, this field is zero.  Otherwise, the
                         first byte of this two byte OCTET STRING
                         contains the error code, and the second byte
                         contains the subcode."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpPeerTable(3) bgpPeerEntry(1) 14 }
    .1.3.6.1.2.1.15.7.2
    bgpBackwardTransition NOTIFICATION-TYPE
      -- FROM    BGP4-MIB
      OBJECTS    { bgpPeerLastError, bgpPeerState }
      DESCRIPTION    "The BGPBackwardTransition Event is generated
                                when the BGP FSM moves from a higher numbered
                                state to a lower numbered state."
    ::= { iso(1) org(3) dod(6) internet(1) mgmt(2) mib-2(1) bgp(15) bgpTraps(7) 2 }
     The list above isn't complete since I can't post a text longer than 25k characters.
  • 3.  RE: BGP4-MIB partial output on HPE 5510/5940/10508 (Comware 7)
    Posted Oct 02, 2017 07:24 AM
    Thanks for the answer, but this is not an MIB-FILE issue (IMHO).
    I'm doing an snmpwalk on the entire subtree .1.3.6.1.2.1.15 with same results - getting only Version, ASN & RID:snmpwalk.png
    As you can see, the rest of the BGP-related information is missing.
    May be there are some configuration missing on my switches, that enable this kind of information visible through SNMP?
  • 4.  RE: BGP4-MIB partial output on HPE 5510/5940/10508 (Comware 7)
    Posted Oct 04, 2017 02:05 AM
    Does anyone configured BGP on HPE 10508, 5940 or 5510?
    If yes, is it possible to retrieve information about BGP peers (bgpPeerState, bgpPeerLocalAddr, bgpPeerRemoteAddr, etc.) via SNMP from this switches?
    Thanks in advance for any help!
  • 5.  RE: BGP4-MIB partial output on HPE 5510/5940/10508 (Comware 7)
    Posted Oct 24, 2017 02:24 AM
    Finally got desired information from L3 & L4 HPE engineers:
    That is correct: only those three OIDs are supported.
    But soon, new code: 2609 will support the following:
     ∙       hh3cMplsVpnVrfBgpNbrAddrTable
    ∙       hh3cMplsVpnVrfBgpNbrPrefixTable
     This code is expected to be available sometime in November.
    So the product is working as designed.
    So at the moment this is known product limitation. Awaiting new releases to fix it...
  • 6.  RE: BGP4-MIB partial output on HPE 5510/5940/10508 (Comware 7)
    Posted May 17, 2019 01:54 AM
    Did you manage to upgrade the device and get the expected result?
    Do you also get VRF peers?
    Regarda
    Christian
