SD-WAN
last person joined: 7 days ago
Forum to discuss HPE Aruba EdgeConnect SD-WAN and SD-Branch solutions. This includes SD-WAN Orchestration WAN edge network functions - routing, security, zone-based firewall, segmentation and WAN optimization, micro-branch solutions, best practics, and third-party integrations. All things SD-WAN!
BGW issue with tunnel to SASE Axis Security
  • 1.  BGW issue with tunnel to SASE Axis Security
    Posted 24 days ago
    Hey,
    I have lab where a 9005 gateway with some AP's.
    When I do a simple setup without SASE or anything I can reach the internet and everything works.
    When I enabled the pbr of axis, then I can not reach the internet.
    I receive a local IP address and can ping the default gateway but couldn't go outside.
    According to Central the Axis tunnels are up and running & on manage portal of axis it says it's also connected.
    When I look into the sessions of the gateway I see that it uses the correct pbr and sends the traffic to axis portal.
    But I see also that the return traffic comes directly and not from Axis.
    Is that the issue?
    In the policy of axis I only blocked gambling websites for testing.
    I made a rule below that allows everything from this test site.
    In the pbr I want that all onedrive traffic goes local and the rest via Axis.
    I applied to the nexthop routing and then the "test" role.
    Any ideas why it doesn't work?
  • 2.  RE: BGW issue with tunnel to SASE Axis Security
    Posted 23 days ago
    Sound like Axis not intercepting?
    Have you created an aaa-profile with an initial role set.
    Have you Applied policy (Config>Security>Apply policy) to the vlan?
    Can it be hitting your setup policy ? just above your axis-pbr policy.
    Verify with:
    show datapath session table
    show datapath route
    show user (is the traffic going to the tunnel)
    other than that this looks fine.
    Ole Morten Kårbø
    ACP - Campus Access Professional
    ACEA | ACSP | APS CX10000 | APS Central | APS SD-Branch
    Netnordic Norway
  • 3.  RE: BGW issue with tunnel to SASE Axis Security
    Posted 23 days ago
    The user has the correct role I already verified.
    I added the route policy where you mentioned, see picture.
    But no succes.
    What I see in the datapath is that it goes through axis tunnel.
    But 2 clients can not do https or https or even say that there isn't internet.
    I can ping to 8.8.8.8 and everything outside.
  • 4.  RE: BGW issue with tunnel to SASE Axis Security
    Posted 23 days ago
    If ping ok and http/https not. Check DNS.
    My setup might be different, but for Apply policy I don't use route acl only role-assignment(aaa-profile)
    Also lan port(G0/0/1) on Gateway is untrusted (the ones with vlan's tagged towards lan)
    Ole Morten Kårbø
    Netnordic Norway
