Ok so we had some visitors from south Africa on our campus, and most had blackberry curve devices. We have our radius server setup using PEAP and have a HA cert from digicert. Everything seems to work fine if the user has an active SIM card and has internet access via AT&T (or whomever). BUT for the users that did not get a local sim, they have ZERO access to any network, and their authentication fails. My assumption is that the BB devices are checking revocation lists for our cert, or something of that nature. I have tried telling those devices without a valid sim to not check the cert, but they still fail.
Radius fails on the password portion for invalid EAP type undetermined.
Then authentication fails
Aruba states: Reason Unspecified Failure
Is there any way around this? Has anyone else seen this issue?
Dan
