Blacklist by MAC address
This thread has been viewed 29 times
  • 1.  Blacklist by MAC address
    Posted May 28, 2014 10:08 AM
    Is there a way to block a MAC address that attempts to connect to our wireless system?? Aruba 650 controller (6.1.3.7)
  • 2.  RE: Blacklist by MAC address
    Posted May 28, 2014 10:12 AM
    In order to permanently blacklist a client (across controller reboots), you will need AOS 6.2
    You can blacklist the client using the following command:
    stm add-blacklist-client <mac address>
    Once you are on AOS 6.2+, you can run the following command to change the blacklist timer to permanent:
    (config) #ap ap-blacklist-time 0
  • 3.  RE: Blacklist by MAC address
    Posted May 28, 2014 10:31 AM
    I updated to 6.2 and ran the 1st command and notice it counting down from an hour under Monitoring>Blacklist Clients.. then ran the second command and saved the config and still see the timer counting down
  • 4.  RE: Blacklist by MAC address
    Posted May 28, 2014 10:33 AM
    After running that second command, re-add the client using the first command.
  • 5.  RE: Blacklist by MAC address
    Posted May 28, 2014 10:35 AM
    that did it!  thanks!
  • 6.  RE: Blacklist by MAC address
    Posted May 22, 2017 08:27 PM
    Are there REST APIs to interact with Clearpass server that we can add/remove endpoint to/from blacklist by its IP or MAC address?
  • 7.  RE: Blacklist by MAC address
    Posted May 22, 2017 08:38 PM
    Which blacklist are you referring to? This thread is about the controller's blacklist.
  • 8.  RE: Blacklist by MAC address
    Posted Sep 13, 2017 10:49 AM
    I'm interested in a way to blacklist a client on the controller (mimicing the CLI command) via API. The API requires IP address which won't work for us - I'd like to just specify MAC address.
  • 9.  RE: Blacklist by MAC address
    Posted Sep 14, 2017 05:45 AM
