Blacklist duration
  • 1.  Blacklist duration
    Posted May 10, 2013 09:36 AM
    One master controller, two locals -- all M3, 6.1.3.2 Blacklist duration is set to 0 for all Virtual APs/SSIDs for both Authentication Failure and Other. Found the bad guy on Local2 and blacklisted him; remaining time is blank as expected. Because you can only use the WebUI to blacklist a connected client, I went to the CLI for Master and Local1 and issued this command: stm add-blacklist-client [mac address]. On both, the remaining time is 1 hour, no matter what I do. Bad guy was able to connect to Local1 last night. Any way to fix this?
  • 2.  RE: Blacklist duration
    Posted May 10, 2013 10:15 AM
    Set the "ap blacklist-time" parameter which specifies how long unassociated users get blacklisted:
    http://community.arubanetworks.com/t5/ArubaOS-and-Mobility-Controllers/Blacklist-Clients-on-3600-controller-ArubaOS-6-1-2-2/td-p/22534
  • 3.  RE: Blacklist duration
    Posted May 10, 2013 10:20 AM
    I thought I had set that, which is why I said, "Blacklist duration is set to 0 for all Virtual APs/SSIDs for both Authentication Failure and Other." Are you saying to do that again in the CLI?
  • 4.  RE: Blacklist duration
    Posted May 10, 2013 10:22 AM
    (Aruba3600) (config) #ap ap-blacklist-time
    That parameter is GLOBAL and not under the virtual AP.  It corresponds to the blacklist time for unassociated clients.
  • 5.  RE: Blacklist duration
    Posted May 10, 2013 11:17 AM
    Thanks! I had not read all the way through the link you sent.
  • 6.  RE: Blacklist duration
    Posted Oct 28, 2014 12:10 PM
    When you say GLOBAL, is that "Set it on the Master and the Locals learn it," or "Set it on every controller?"
  • 7.  RE: Blacklist duration
    Posted Oct 28, 2014 12:27 PM
    Global meaning all SSIDs broadcasting from APs connected to that controller.
    You need to blackilist clients on each controller.
  • 8.  RE: Blacklist duration
    Posted Oct 28, 2014 01:13 PM
    Ah, good point.
    I hadn't thought of that -- I was refering to where I set 'ap ap-blacklist-time 0'
    Is that a Master pushed configuration bit, or will I have to set it on each controller.
