Blacklisting 8.6.0.3
  • 1.  Blacklisting 8.6.0.3
    Posted Apr 07, 2020 06:51 AM
    Hi
    8.6.0.3 Gui blacklisting feature, I can correctly blacklist a client.
    However when removing the client from the Blacklist table, the client correctly connects again however the table doesn't update and continues to show the client.
    Anybody else seeing this issue?
  • 2.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:02 AM
    I am not seeing this.
    What steps are you using?  Are you observing/executing the blacklisting from the MD or the MM?
  • 3.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:06 AM
    Managed network> Dashboard> Security> Blacklisted Clients
    Selecting client, delete option.
    Following instructions provided, bottom of page 606.
    https://support.hpe.com/hpesc/public/docDisplay?docId=a00092459en_us
  • 4.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:17 AM
    Got it.
    Is this a standalone or MM-based network?
  • 5.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:21 AM
    MM-HW-5K, managed network with clustered, 7240XM
  • 6.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:27 AM
    Does the device appear and disappear when you type "show ap blacklist-clients" on the MD while blacklisting and removing on the md?
  • 7.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:47 AM
    Yes when adding the client I can see it defined as "user-defined centrally" and it removes correctly.
    I have just blacklisted and removed the client again. This time it has removed from the Gui - Strange.
    I know for sure the client was working previously (when not blacklisted and showing in the Gui) as it is a Cape that I am blacklisting.
    Consider this resolved, unknown random Gui error.
  • 8.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:51 AM
    When did you upgrade to 8.6.0.3?
  • 9.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 07:56 AM
    1/4/20
  • 10.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 08:03 AM
    All I can say is to clear your browser cache on your MM that you use to blacklist and see if you can still replicate.  We will check on this end to see if there are any reports of this.
    Thank you for bringing it to our attention.
  • 11.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 08:09 AM
    8.6.0.3 was released 3/22/2020.  When did you upgrade to that?
  • 12.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 08:16 AM
    I provided date in UK format. That's probably caused confusion
    In US format.
    I downloaded software 03/31/2020
    I upgraded on 04/01/2020
  • 13.  RE: Blacklisting 8.6.0.3
    Posted Apr 07, 2020 08:19 AM
    Got it.  Thanks.
