Hello.
I'm not sure what you mean 'connecting onto switches'.
As cjoseph wrote, you can use Control Plane Security feature to authorize APs to connect to your Aruba controller.
Or if you mean connecting APs to wired switch, you can use 802.1x on switch for authorization your APs (wpa supplicant on AP). You can setup it on provisioning page.
Regards
Jaroslav
