Block Personal Phones from Corp WiFi
  • 1.  Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 01:37 AM
    Hi Guys
    Currently running clearpass server 6.7.9 with 802.1x and wanted to know if its possible to block personal phones/ipad from joining corp network.
    Currently anyone who has AD cred are able to sign in and abuse corp network and we wish to stop this.
    We hav
    Any thoughts
  • 2.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 01:42 AM
    Couple things you can do.
    1. if its a corp phone and is under MDM then you can put a rule stating that if not in MDM deny from corp wifi.
    2. If you have a list of authorized devices then use it as a authz source and only allow those phone/ipads.
    3. Use a custom attribute and tag each of the corp phones manually then make a rule only allowing phones with that attribute.
  • 3.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 01:45 AM
    thank you for quick response.
    we do have MDM in place but how would clearpass identify if its in MDM or not.
    are you able to give me n example
  • 4.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 01:46 AM
    You can also move to EAP-TLS and either Onboard the Corp devices with a certificate issued by ClearPass as a CA or leverage an internal PKI to issue certificates for Corp devices.
  • 5.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 01:47 AM
    What MDM do you use?
  • 6.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 01:48 AM
    Airwatch
  • 7.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 01:49 AM
  • 8.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 06, 2019 02:28 AM
    @arpitb wrote:
    Refer Enterprise Mobility Management section here:
    https://community.arubanetworks.com/t5/Security/ClearPass-Docs-Configuration-amp-Integration-Guides-Solution/td-p/522283
    i get the following error when i set it up.
    Error code: 401 Verify Proxy settings, Server credentials and retry.
  • 9.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 06, 2019 03:17 AM
    Server is unable to reach your Airwatch instance when it's trying to poll for that information.
    If you have a proxy setup in ClearPass you will have to allow this communication.
    If communication is fine, double check the credentials being used.
  • 10.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 08, 2019 06:53 PM
    would allowing it to bypass work?
    Any logs i can look at>?
    we dont have a proxy server.
    credentials seems fine as i am able to login onto a test machine.
    anything else i can check?
  • 11.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 09, 2019 06:42 AM
    Logs : Event Viewer and PolicyManager > MDM
    Open a TAC case, they might be able to use curl to see if you can reach over https. Ensure you are able to use the FQDN of Airwatch portal and can ping it from ClearPass CLI. Sometimes it could be as simple as DNS resolution.
  • 12.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 10, 2019 10:58 PM
    clearpass is now able to communicate with MDM and imported all devices.
    what rule should iput in place?
  • 13.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 11, 2019 12:29 AM
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=33307
    Pg 14 and specifically Pg 18. The attribute might differ based on the EMM/MDM vendor.
  • 14.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 11, 2019 12:31 AM
    doh
    completely forgot about that.
    thanks will look into it
  • 15.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 11, 2019 09:31 PM
    how would you deal with devices which are already connected to corp network?
    would you reboot AP's or delete endpoints?
  • 16.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 12, 2019 01:43 AM
    Delete from controller user-table. They should reconnect and get new policy.
  • 17.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 12, 2019 02:10 AM
    you mean do a bulk delete from endpoints in clearpass
  • 18.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 03:19 PM
    Under the service, you can enforce to match if the device is an object in AD then allow access, pull informaton from your Active Directory (Source).
    AP
  • 19.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 05, 2019 07:03 PM
    we have that rule currently but its doing OR instead of AND.
    if i change it none of mobile device will connect which is not i want.
    Is that what you meant by your statement?
  • 20.  RE: Block Personal Phones from Corp WiFi
    Posted Sep 08, 2019 02:50 PM
    Just add another rule under enforcemen for that service, it will pick top to bottom.
