Block Ports on Aruba WIreless
  • 1.  Block Ports on Aruba WIreless
    Posted May 14, 2017 11:54 PM
    Hello all,
    I wanna try to block some port to avoid WannaCry Attack..
    and my question..
    How to block port on aruba system?
    i tried search on google, but i didn't find it.
    for anyone who answer my question.i say big thanksss ^^
    Chris
  • 2.  RE: Block Ports on Aruba WIreless
    Posted May 15, 2017 12:46 AM
    The only effective way to handle this would be to use ClearPass OnGuard to verify that patches are installed.
    SMBv1, v2 and v3 all use the same ports and this affects SMBv1. Blocking SMB will likely wreak havoc in your network.
  • 3.  RE: Block Ports on Aruba WIreless
    Posted May 15, 2017 04:31 AM
    Dear Cappali
    Im Just test on my network, whom has fully backed up..
    If my network going wrong, i just do backup on my network  :)
    now im not use clearpass , just simple configuration
    but now i dont know how to block port on aruba , can you tell me how to block port on aruba system?
    Thanks & Regards
    Chris
